Looking for a small case
19 May 2004
As title. Wanting as small a case as possible.
Mobo is a gigabyte ga-h170-hd3
G card is a gigabyte 1080ti
Essence stx sound card
2 sad drives and one mechanical drive
Corsair cx600 power supply
Not looking to upgrade anything in the near future and I can leave the sound card out if need be as I use a headphone amp now.
Any suggestions appreciated
Website says max gpu length 280mm
Possibly not to interfere with tall PSU plugs when motherboard PCIE 16x slot is closest possible.
OP PSU is 150mm long and PCIe is the second slot, no interference.
Like I said, my GPU is 297mm and I have 3.5 HDD mounted. The space between is enough to run AIO tubes through and leave 15mm clearance
Don't get me wrong, there is no free space wasted. It is a tight fit and tricky to assemble. But final package in Thetis is as compact as ATX can get. With full size PSU, GPU, CPU cooler.
Nice case! Will 1080ti fit? My 3080 won't otherwise may have nabbed one ;)
At 305mm 3080 should fit if not using AIO.
But it will surely heat up the case.
