Looking for a spec for a high end system
24 Mar 2004
Hey guys
Not built a system in ages and need a spec for a something that's going to be used for a main office pc doing multiple tasks and advanced photoshop using a dual monitor set up.
Looking to build a top spec machine to last beyond 5 plus years.
It will not be needed for gaming and prefer intel based system
I have a 2nd 2TB HDD here already so only needing a SSD for the system drive.
Budget looking at around £1000-£1250
thanks
You prob won't actually need very much, a skylake i7, m.2 ssd for fast storage. You really don't even need a GPU, can run 2 monitors off the igpu without hassle, and if you're not doing 3d rendering the pro GPUs don't really offer much advantage.
My basket at Overclockers UK:
Total: £844.00
(includes shipping: £11.10)
I think this will all fit together. Got the 6700K so you can overclock it down the line if you need more speed. Lots of ram, with a couple extra slots if you want more. Micro ATX so you have lots of case options to suit your space. And you have the option to throw a GPU in if you do find you need one. Worth double checking the m.2 compatibility. I think this one will fit, but not 100% on them. :)
