Looking for a switch that can do isolation by port
6 Jan 2008
Hi there,
I'm wondering if anyone know of a switch that can do port based client isolation (which can be port selected?).
Thanks
Yes - but when I say isolation, I don't mean using vlans, just port isolation.
I.e. much like an AP you can set it to isolation so clients cant see each other.
I'm using Netgear Pro GS724AT's and i cant find the option for this on this switch.
Well I think just about any recent Catalyst will support port security, and their AP's all support OSPF as far as I know.
The GS724T is only a Smart Managed switch. If you want to stick with NetGear, look at the GSM7224 which is layer 2 managed and can be configured for Private VLANs.
Hmm. I did say I can't use vlans?!
Everything needs to based on the same ip range and I route tables will not work with what I need.
I actually need port isolation.
Different vendors call it different things ;) HP call that Protected Ports on the ProCurve 2810.
ftp://downloads.netgear.com/files/GSM72xxPS/7000_SWA_8.0.2_10Mar10.pdf
The private VLAN Group allows network administrator to create groups of users within a VLAN that cannot communicate with members in different groups but only within the same group. There are two modes for the private group. The mode can be either “isolated” or “community.” When in “isolated” mode, the member port in the group cannot forward its egress traffic to any other members in the same group.
