looking for a vaping kit
14 Dec 2005
I had a shot of one today, it had an adjuster on it so it was easier to take a draw.
Are there any kits that are set like that all the time or would I need to get one with adjustable airflow to get that effect?
The one I used today was massive, would prefer a pen style one
The massive ones might be bulky, but for less than the volume of 20 super kings, or a rolling tin you get a good long supply of vaping.
I'd also reccomend the nautilis/istick combo, cheap enough not to break the bank if it isnt your thing but good enough to get you hooked. It's how i started about 4 months ago and i've only just jumped up a bit with my second rig but i still find myself going back to the nautilis for flavour/longevity.
Dont bother with the really low end stuff (especially the cartridge ones) they'll just put you right back on the smokes.
As above, I have a Nautilus mini tank on an iStick 50w and it's never gone wrong. Days worth of charge at a time, adjustable everything (voltage/wattage, airflow etc) and it only cost about £70. That sounds a lot until you realise it's about a week's worth of fags and will last you years if you look after it. I'm now 11 months smoke free. :D
