Looking for advice on a new pc build
13 Feb 2009
So its been around 5 years since i built my last pc and i'm now looking to do the upgrade dance again.
My current spec
i7-7700K CPU
geforce 1060 6gb
16gb ddr 4-3200 (1600mhz)
Z270X- gaming 7
corsair rm850 psu
Its a gaming pc i'm after, budget would be around the £600-£700 although i could push the budget a little higher if it was really worth it with the idea being i wont need to upgrade for another 4 or 5 years.
Any recommendations?
Couple of queries,
How big a deal is having ddr5 ram as opposed to ddr4?
How important is it to have a cpu and gpu that are a similar spec from a gaming performance perspective? Is it bad having a gpu that outperforms the cpu or vice versa?
Sorry posted this in the wrong forum please delete
Id probably get something like a Ryzen 4500 and mobo and reuse the RAM you have/ Pair it with a 6700XT and youre good to go and should be a decent upgrade.
1 X AMD Ryzen 5 4500 Six Core 4.1GHz (Socket AM4) Processor - Retail - £74.99
SKU
: CP-3D4-AM
1 X Gigabyte B550M DS3H (AMD AM4) B550 Micro-ATX Motherboard - £89.99
SKU
: MB-5BR-GI
1 X Asrock RX Radeon 6700 XT Challenger D 12GB GDDR6 PCI-Express Graphics Card - £349.99
SKU
: GX-00X-AK
Grand Total: £522.96
