Looking for advice on first build
27 Jul 2016
Hey guys, I'm looking to build my first PC but I'm honestly quite overwhelmed by the amount of choices out there. I would massively appreciate it if someone could help me find a build suitable for what I need, for a budget of around £800. (if you believe I desperately need to go higher then don't be afraid to let me know too).
I'm a digital artist so primarily I just need a computer that is going to run photoshop and 3d modelling programs with ease, but I also make youtube videos and would love to be able to stream games like Overwatch or maybe Battlefield in the future with 100+ fps.
For now, something like a 250gb SSD and 1 stick of 8GB RAM is fine for me as I can upgrade it at any time in the future, and of course getting a hard-drive is pretty simple. I'm not one to care about making the computer look as aesthetically pleasing as possible so I mainly want function.
Thanks for your time!
Yo,
Do you need Windows, peripherals such as keyboard and mouse etc?
What exact programs do you use to edit/model?
I have all the peripherals I need, and I use photoshop/clip studio paint/3ds max for the art side of things and I record/stream games with Open Broadcaster Software and edit with Sony Vegas.
Here are a couple of builds that I have thrown together. These are totally a guide, and quite swayed by my personal preference
You could just about squeeze in an x99 system, this would offer the best in terms of professional applications, however you may struggle with graphics power unless you spend over budget.
My basket at Overclockers UK:
Total: £709.10
(includes shipping: £13.20)
If gaming performance is more important then you could go for a configuration like this, I had to go lower end on the power supply/cooler and case to fit it in the budget, you could spend less on the gpu and more on the aforementioned.
Total: £821.49
(includes shipping: £12.60)
Otherwise you could go for a skylake i5 and spend more elsewhere like this:
Total: £812.87
(includes shipping: £0.00)
Sorry if I have just added to your confusion. It really depends where your priorities are, seeming as gaming seems a lesser priority then I would go for the 5820k/6700k and drop in/upgrade your gpu when you feel like it
