Looking for advice on how to integrate a forum into a Joomla site
10 Jun 2010
Scotland
I'm looking for a bit of advice on how to integrate a forum into a Joomla website. I would really love to use Vbulletin like OcUK as I think it's a cracking forum style.
My knowledge is pretty limited with regards to web design, I tend to paint by numbers.
If you need to see the site, let me know and I'll post it up.
Cheers.
If your host comes with cPanel you will have a thing called Softlicious which is basically a list of scripts that automate the install of many different CMS's, forums and other stuff. It's what I used to get my Joomla CMS installed initially. I then put Kunena forums on via the Joomla install after that.
After that it's just a matter of creating the various forum sections and categories that you want in place and a menu option pointing to the forum...or you can have it visible on your front page should you wish.
Here's the one I did. It's totally average but it's fine for us : www.swedgeville.org
The option to install vBulletin won't be available to you however, as it's a paid for forum. If you really want it then heading over to vBulletin and seeing what they say about integrating it with Joomla is the way forward.
A note of caution : Don't use Joomla 1.6 with Kunena if you do decide to go that route, as it's as buggy as hell at this time. Stick with Joomla 1.5.22 for now.
Thanks' very much, I'm going to have a bash at it now. I'll keep you posted how I get on.
Your site looks really good, when you said you can have it on the homepage... is that the way yours is setup. I would like mine to be like Ocuk, where it's a different site altogether, of course linked... but no sign of the homepage, so people can login directly to that.
No, I don't have it set up like that. I want people to hit the front page and see the main menu there and read the "about us" first. We're a gaming guild and don't want any old riff-raff applying to join us ;)
If you want your forum to be the first port of call :
1. Log in to the Joomla administrator backend.
2. Go to the Kunena menu or wherever your "Kunena Forum » Entrypage" menu item is located.
3. Click on the checkbox on the left and click the Default button in the toolbar.
From what you're asking though, it sounds like you'll need to find a plain "one column" Joomla template to get a similar look to this here...and a dynamic one at that (not fixed width). One where you can put up a banner / header logo at the top saying who you are and then have the forum covering the full width of the page below this.
