To be running inside a Silverstone SG01, with a 4870 1gb, 4gb of Kingston 6400 RAM and a Corsair HX520 PSU.
I'm looking at either the AMD Phenom II x4 945 or the Intel Q9400 CPU, and am edging towards the AMD simply as I've never tried an AMD chip before, and performance seems pretty identical.
SO I need a motherboard (and have no idea what I'm looking for!)
Spec-wise, the Gigabytes look like good boards, and if they get strong recommendations on here I'll go for one; however, my current board, a P35c-DS3r, has been pretty unstable and dodgy ever since getting it a couple of years ago, so I'm a little wary of Gigabyte.
Finally, I am right in thinking that you can run an AM3 chip in an AM2+ board aren't I?
When installing the 4870, I assume that I'd have to "switch off" the integrated GPU - is this easy to do through the BIOS?
EDIT: Should have said that I don't really want to spend more than £100 on this, as I will probably switch it out for an AM3 board within a year or so.
