Looking for an upgrade but haven't a clue where to start!
1 Dec 2014
Hey guys
no my way around a computer but when it comes to components and upgrading it is alien to me lol so wondering if anyone can help me. Looking at spending around £150-250 on a new graphics card. currently AMD but don't mind swapping to an NVIDIA if its better quality.
My current pc spec:
Motherboard : ASUS M5a87
Chipset : AMD 870
Processor : 4x AMD phenom(TM) II 970 processor 3.5 ghz
RAM : 2x 4gb DDR3 PC3-12800 Unbuffered NON-ECC 1.5V 512Meg x 64
Graphics card : ATI RADEON HD 6670
PCI Express x16 with a 15 hole connector.
any help would be grateful.
Thanks guys!
R9 290 is a power house and fits your budget just right.
But the GTX 970 is also a very good card, its all down the what team you like
I wouldn't want to attach an amd 290 gpu to a 450w power supply. The nvidia 970 should run off it assuming it's not an awful cheap psu but may be limited a bit by your ageing cpu. If you've got 250 sheets for an upgrade it's worth giving it a try! The most that can go wrong is you'll be cpu bound in some games as long as your psu is ok.
Last friday or even yesterday you could have probably squeezed a new psu and an amd 290 into your 250 budget if your existing supply is cack.
I'd certainly look at upgrading that Psu even if it can run a 970, I'd have thought a minimum power requirement for either a 970 or R290 would be about 650w quality psu to give a bit of overclocking headroom.
970 would be better if you have a lower power PSU. However, it depends if you need the Nvidia specific features or not, if not then the 290 is a good option.
Neither a 970 or a 290 is a good option when your CPU is only a " 4x AMD phenom(TM) II 970 processor 3.5 ghz" it would be a bottleneck in my opinion, especially at stock.
