Looking for an upgrade
5 Aug 2006
Derbyshire
Afternoon OCUK.
As 2 months time I will be 23, 2 years ncb, driving for 6 years and will be living in the second best area code. The car will be kept in a private multi-storey covered in cameras, so getting it bashed isn't likely to happen.
I drive a 2000 1.0 micra. It has been brilliant and cost me 1 hour of labour to fix in the 6 years I have owned it. However, it is time for an upgrade.
I start getting paid each month and within 2-3 months I can top-up my car savings to have £5000. In 6 months I could have £8000 though.
I don't really need a car but I am torn between keeping the Micra as it is mechanically perfect, or to upgrade through nothing but pure want. I would be doing about 3000-5000 miles per year, so diesel can sod off.
I would like something with a touch of poke to it, aircon, electric windows - Not exactly narrowing it down am I :p.
I have had insurance quotes on many hot hatches and the only ones that came in over £1000 were imprezas (£1600 for the 300hp STI).
I have been looking online at the first generation Skoda Octavia VRS. The insurance comes in at a decent £750ish (£200 less than a Golf GTI!) and the car is significantly cheaper, yet has the same powertrain. I have also looked at Golf GTI's MK4, Leon Cupra MK1 (inc. R), Civic Type-R, Mondeo ST220. I have also looked at Jettas as they seem to be a 'Golf Saloon' yet are very reasonably priced.
The Mazda 3 MPS is going in the bin as I am not paying £450 to tax a car, but I have no issues with £250 tax ones.
I want a car that is fun with decent reliability.
I have test driven nothing at the moment.
3000miles p/a = under 58miles per week.
5000miles p/a = under 97 miles per week.
Your mileage per week is less than mine yet I don't use my car from Monday to Friday as I work and live in my truck all week....
It seems a tad low to put it mildly! ;)
If its accurate, then you may as well find a nice V8 or V12!!! (although your insurers would probably think otherwise alas)
Your mileage per week is less than mine yet I don't use my car at all from Monday to Friday.
I live on Campus and have no need to drive to work. I would drive 5 miles a week to Tesco and possibly the 80 mile around trip to home may be twice a month.
In 6 years the Micra has done 22,000 miles and one of the years I worked 5 days a week in one place then Sundays somewhere else that was an 80 mile around trip, which means some years I only did 3000 PA.
Tbh in that case I'd keep the Micra if I were you (painful as it may be with an itch to change), keep saving & have something really* nice once you graduate. :)
* NOT an MG!:p:D
We've already seen one prominemt Motors member chage 'for the sake of it' and he isn't happy, and trying to flog it off. My advice - stick with the Micra till it dies!
A man with impeccable taste ;)
I love my one but that is because of the mix of practicality and performance on a budget. If you don't need the practicality of a hot hatch how about something like an MX-5?
Assuming we are talking about Fox he bought a new car because his spreadsheet told him he could have a newer car for the same monthly outlay. Completely different to the OP's situation of wanting something new for change sake.
I am 6ft 3 and a bit chubby, so no MX5 I am afraid!
I have briefly considered the idea but I would want a hardtop (a soft top convertible is just madness in the UK!) and these cost a fair bit more.
Is that really a deal breaker??
Any extra 50/60p per day...
Almost half my monthly income on tax just seems mental. Especially when it pays for a small white circle in my windscreen that does absolutely nothing.
I had the Micra at 17. I said I will keep it until University ends. Then I did a year and changed course, just one more year extra. Then I did a placement.
The time has come where I have put up with a slow, uncomfortable car all my driving life and just want something nice for once.
Everything works on the Micra, if I keep it until it dies it could be another 5 years.....
Clio 182 :p
Focus ST must be in that price range also?
Members on here have posted about their Clios and it seems they need a lot of repairs each year to keep on the road.
I have also heard they are uncomfortable for tall drivers.
An ST Focus can be had for £7000-8000 for a 2007 one.
I forgot to mention, I point blank refuse to purchase a Peugeot, a Citroen or a Vauxhall :p.
That is pure pot luck, they are pretty cheap to run. 35+mpg on a long run.
Servicing is dirt cheap, brakes etc are all very cheap. Yes the belts have to be changed at 36k but then its expected.
Is a MK1 Octavia a good bet? A relative's (who is very good hand-on with vehicles) son had a Leon Cupra MK1 with the 1.8T engine and it was a nightmare, but I don't know the condition nor mileage of the vehicle. I have heard the 1.8T is pretty reliable though.
I just see the Octavia as really good value almost-hot car, that looks good yet with a VAG drivetrain it should be pretty good at not breaking. I have looked at Leon's online and it seems they have various niggling issues.
The 1.8T engine can be quite niggly don't think VAG = trouble free. My 306 in comparison was MUCH more reliable than my Octavia and it was both older and higher mileage.
My one has needed 2 coolant sensors, lamda sensor, clutch and DMF, 2 front springs, tie rod, a section of wiring loom, oil level sensor, steering rack, new coil packs and probably some other stuff that I forgot :p on top of the usual consumables. That is in 4 years and just shy of 60k.
That said I agree with you when you say that it is a good value warm hatch. I also think it looks better than the Mk4 Golf and Leon alternatives but that might just be me :o
If you want to take it from a warm hatch into dipping your toe into hot hatch territory a remap will see it at over 200bhp with shed loads of torque and a rear anti roll bar is the best bang for buck you are ever likely to get from a handling mod.
Links? When did he decide he wanted to flog it?
I thought he bought it outright, not on tick?
