Looking for an upgrade.
24 Nov 2002
Abertawe, Cymru.
I'm currently running a 6750XT 12GB card I play on a 1440p monitor, budget is £500, I mainly play stuff like flight sims etc, is it worth upgrading? Been out of the loop for last few years so any suggestions?
My rig is in my sig.
Cheers.
SJ.
What you have now is a good pairing, I personally wouldn't bother unless you're not able to use the settings or achieve the framerates you want at higher res/details.
If you got a 9070/9070 XT you'd end up wanting a CPU upgrade too and...
5900X and a 9070XT will be absolutely fine and that would be the route I would be going with current prices of gpus and hardware in general.
