looking for case for dual 480 rads but cube shaped
28 Jan 2015
Any ideas if the above actually exists as client has gone off her Enthoo Primo as she would like it to fit under a shelf which is approx 660m in height
THanks
I don’t think cube and 480 is going to be what they want if the primo is a bit big. with the cubes the long rad is usually front which means the resulting case with two is really large...
Like the Lian-Li 8Pack would take a 480 plus others but it’s massive (I have it). If it was me I’d be looking for a dual 360 instead probably, unless they want a server under that shelf ;)
Mountain Mods UFO with extension kit will allow for either three 480s or up to six 360s depending on panel selection.
Anything else that would fit either dual 360 or a 420/360 combo- cube not required
I think some of the Lian Li cubes can shoe horn two 360 rads in - but if the client is not set on a cube or just the directive it needs fit under the shelf many mid towers will fit the bill so you have a lot more design choice.
There’s an enthoo mid I believe which would work, but basically you now have loads of choice!
