Looking for correct sound drivers
14 Oct 2008
I recently bought the "Primo Pro" and I've got it setup and all working great, however I'm having problems finding the right sound drivers, the ones I managed to find to get any sound at all work but some sounds come out poorly or not at all, two examples being whilst playing San Andreas the radio will constantly cut and, and on Warcraft opening some of the character screens sound muffled.
So pretty much I was hoping someone could direct me to where I can find some proper drivers.
The PC has an "Asus Vintage V3-M2NC61P Barebones" mobo.
Any help is much appreciated.
Link to the PC: http://www.overclockers.co.uk/showp...MD Athlon X2 5600+ 2.80GHz SILENT DDR2 System
That definantly helped a bit, however there problem still occurs with sounds bugging and turn off within San Andreas occasionly, I might try uninstalling all the drivers and putting them back on again, its slightly confusing though, within the download theres quite a few different install files.
Right, well after trying various drivers and the problem not going I tried some other things, mainly being altering hardware acceleration, which did remove the problem, but that caused all my sounds to be delayed in all my games, so that went back to full.
However after looking specifically into SA I found other people get this problem, generally just when its raining, one thing I did which helped somewhat and removed the tiny problems with other games was to switch my sound setup from Stero Headphones (which im using) to the Stero Speakers setting.
So problem pretty much solved.
