- 27 May 2014
HI everyone.
I recently decided that I was in a position where putting together a PC was a possibility but after looking around I am swamped by the different specifications and compatibilities. As far as I understand as long I have compatible (AMD & ATI/Intel & NVidia) components everything should work, but I am guessing it is more complicated than that to get the optimal build. The current components I provisionally plan to use are:
The basic questions I am here to ask are:
Are any of these components vastly out classed by a component for similar price? The only stipulation on by build is I would like it to be Nvidia and Intel but apart from that I’m easy. I would like to spend around £1000 although slightly more would be ok if it meant improving something that I am not likely to upgrade.
Any help would be greatly appreciated, Thanks!
- CPU: Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
- Motherboard: MSI Z87-G45 Gaming Series Intel Z87 (Socket 1150) DDR3 ATX Motherboard
- GPU: MSI Geforce GTX 770 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card
- RAM: Avexir Blitz 1.1 Original 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz Dual Channel Memory Kit
- SSD: Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic
- Case: NZXT Phantom 410 Enthusiast Midi Tower Case - Black/Orange,
- What PSU would be good for the above build? I understand modular is preferred but with so many different models available which would be the best for me?
- Is there some form of cooling I am not considering? I see a lot of builds which have CPU coolers are these optimal or completely necessary?
