Hi,
Looking for some help and advice please.
My current system is groaning and creaking a bit under the weight of the latest AAA games (my pc is mainly used for gaming) and I am thinking about upgrading it in some way to try and improve my frames per second, smoothness etc etc.
I 'try' to build my systems to get the best bang for my buck from each component and hope that they will be future proof (as much as anything can be).
My current system specs are: (system was last upgraded about 2 to 3 years ago)
CPU: I5 4679K @ 3.40
MOBO: Gigabyte Z87X-D3H (with a Noctua NH-D14 heatsink)
RAM: 8GB DDR3 @ 1000Mhz
GFX: MSI R9 280X 3072MB
MONITOR: BENQ XL2411T Gaming monitor 144Hz
I have 2 samsung evo ssd hard drives, 1 has my OS on it(an 840 EVO) and another is set up with my games(an 850 EVO).
Soundblaster soundcard.
All of my components are running at stock.
I was thinking that the best upgrade I could make with the biggest impact would be my graphics card, but I am unsure if I will just move the bottleneck to a different area and should therefore be looking at something else?
Given that I am right and the graphics card is what I should be looking to upgrade first i reckon the 480X or the 1060 would prob the way to go for me.
As far as I can tell the 1060 does perform slightly better at the moment but as I am looking to buy something that will last for a few years I was thinking the 480 would be the way to go.
So was thinking about this card:
https://www.overclockers.co.uk/sapp...-pci-express-rgb-graphics-card-gx-37b-sp.html
or perhaps something similar?
What I am looking for is any kinda feedback or advice you can give me in any area, as you can tell I am not the most clued up about this kind of thing and would appreciate any help you can give me.
Is it the right component, is it the right card, best value for money etc?
My budget is such that I could manage the 480/1060 but wouldn't be able to stretch too far beyond that value for the time being.
Thanks a lot in advance for any help, cheers
