Looking for MIDI case with dust filter
Right now I have a Antec Super LAN Boy case, and I have about £60 to spend.
For £60 the only better case out there is the PC7+II.
Spend 50p/£1 and get a filter, then spend £50 buying a new HSF for your graphics card and a Silenmaxx enclosure for your hard drives, or some new fans.
The Gprahics card with its stock heatsink will be making a awful lot of noise, whatever case it is in!
What spec and we can reccomend some stuff...
FG-020-AK Akasa AK FC-06SL Fan Controller Junior - Silver (FG-020-AK)
£7.50 £7.50
FG-000-AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR)
£15.95 £15.95
SY-008-ZA Zalman VF900-CU Quiet Copper VGA Cooler (SY-008-ZA)
£20.95 £20.95
Subtotal £44.40
VAT £7.77
Total £52.17
If you have an athlon 64 that would work
£15.95 £15.95
Have this already.
Where do I get dust filters from? Cheers :)
Ok, so I have a dust filter - only to find it is impossible to fit it to the SuperLAN boy - installing a dust filter (which is haphasardly done as is, if you can get it fitted) means you cannot fit the front plastic facia back on...
Try fitting it between the fan and its screws, screw it onto the back of the fan, on the insde of the grill etc.
There will be a way, the filter does not have to come before the fan.
