I'm sensitive to pwm and can get a headache from monitors that use it(only LED though CCFL seems to be ok)
http://www.tftcentral.co.uk/articles/pulse_width_modulation.htm
I was really happy to see the DGM IPS-2701WPH does not use pwm however the contrast ratio is awful
Average Contrast Ratio = 544:1 (from tftcentral)
Compared to the Hazro HZ27WA
Average Contrast Ratio = 943:1
At the moment I'm using a samsung 215tw which is a va panel, so I think contrast ratios could be a problem for me since I'm used to fairly good black levels.
So the DGM would have been perfect until I found out about the contrast ratio. The Hazro might be good but I can't find any info on if it uses pwm.
Does anyone know about the Hazro and pwm or maybe can recommend something else for me?
