Hi all,
I'm new to the forums but not to OcUK.
Basically, I'm looking for a new monitor that has either component or scart inputs on the back, as well as DVI, as I'd like to be able to connect it to my Wii as well as my computer.
I currently have a Samsung SyncMaster 22" (can't remember the model number) which only supports VGA and DVI. I think it was one of the ones where there was A, B and C models and know one really knew what you actually got.
Anyway, I've been looking at 24" and 22" monitors. I would prefer a 24" as this would make the upgrade more worthwhile.
I've been looking at the Dell 2408WFP Link
However, the cost as well as the reported input lag problem have put me off this one.
I've narrowed it down to two. The Samsung T220HD Link
and the Hyundai W240D PVA Link
Now, I would prefer the 24" Samsung T240HD. However, I've only been able to find the T240 and NOT the T240HD, as the non-HD models don't support component input and the built-in Freeview is a plus. It does exist (I think lol) as I've seen it on a review site. My concerns for this monitor, though, are the wobbly stand and reported backlight bleed (which is noticeable and possibly increased by the gloss bezel).
The Hyundai seems great as its quite cheap (for a 24") and has all the inputs I need. I am a bit confused over the performance differences of TN and PVA screens. Also, what is the difference between the 240D and the 241D? For any owners of the Hyundai, the bezel looks quite thick. Is it 'overpowering'? Does it take over the screen?
Lastly, the Dell comes with a zero dead pixel warrenty/guarrantee. How do the Samsung and Hyundai models compare with this? My current screen has two dead pixels, and whilst not in the way, they are very annoying to see out of the corner of my eye.
I've got an 8800GTS 512 (will that be enough?) and will be using the screen mainly for gaming, movies and browsing. I'm not a huge gamer. I just play a bit of TF2 and CoD4 and some RPGs.
Many thanks
Many thanks
