okay, this is the best that I can do
the stars of the show are a 240hz OLED monitor, (amazing colours, and deep true blacks,)and a 4070 super to run it!(great graphics card,)
the power supply is future proofed at 850w, and has the 16 pin connector used with the best, and future nvidia graphics cards, should you slip one in later on it is also used with the 4070 super selected,
you could save just a little money, by getting a " thermalright peerless assassin SE ARGB air cooler " from the rainforest, as ocuk only has them on pre-order atm, this would give you more headroom for overclocking the CPU, which is overclockable, you might not be into overclocking yet, but it is fun to tinker, and it means that you can gain some performance later down the line, the CPU also has onboard graphics, should you ever need them, should you have a problem with a graphics card breaking, for example, or if you just needed to reuse the pc a small workstation later on
the awesome monitor has g-sync to go with the nvidia GPU
I can't fit in a windows DVD because I don't know if you have a dvd drive, and the case does not have a space for a dvd drive anyway( i might be wrong, looking at the case again, it looks like it has a vertical drive bay, if you do already have a DVD drive)
maybe you already have a windows 11 installation on a usb stick and you are only getting the oem DVD win11 for the key? you can get cheaper keys elsewhere than £100, or you can just use windows without activating it ,,for free, I've been on free windows 10 for years I thought that ocuk sold win 11 on usb, but I guess not ,because I can't find it!, anyway you will have some decent change from £2500 so, it is up to you what you do with it, I left money aside for an OS
the listed place holder air cooler has pre appplied thermal paste on it(I've double checked)
My basket at OcUK:
Total:
Total: £2,411.83 (includes delivery: £0.00)
HERE is a basket link to make your life easy, I think this will do CS2 at high refresh rates at 1440p on the bloody fantastic selected monitor
