Looking for pgrade advice
23 Apr 2007
Cardiff-ish, Wales
Hello all,
My son is looking to upgrade his GPU, he's struggling to play Elden Ring, Hell Divers 2 etc without reducing graphics to minimum.
He's got a 1660 Super GPU, AMD 1700X and 32Gb ram. Running at 1440p.
We're looking at something like a 4070, £500 ish budget. Any suggestions?
Is it also worth looking at refreshing the CPU? The motherboard is an MSI B450 Tomahawk Max, socket AM4.
Definitely. 5700X3D is the optimal choice, but 5600/5600X would still be a nice upgrade for gaming.
Have a look for deals, but anything from: 7800 XT, 4070, 4070 Super and 7900 GRE are all good upgrades and at least twice as fast.
This is solid advice and exactly what I'm planning.
I'm on b450 board with 3600x +1070ti for example. GPU upgrade next and the 7800xt/6900xt are high on the list
Is £500 your total budget or just for the GPU?
EDIT
You could get a 6750XT and a 5700X3D for under £500
No idea how good the 6750XT is but apparently it's good for 1440p.
That board with the right BIOS will let you run a 5700X3D (~£140)
Leaves £360 for a GPU, 7800XT might be a good balance and is at that price-ish
Also selling your old CPU (~£30) and GPU (~£90) would net a little money so you could offset/spend more
Just echoing this point by Tetras and a couple others as the best solution.
No need to replace the whole machine - the 5700X3D is fantastic.
Update the BIOS first before you start doing any upgrades tho.
