- 16 Jul 2011
So, using that awesome cart plugin for chrome, I have currently the following build in mind:
YOUR BASKET
1 x Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card £459.98
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM £233.99
1 x Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black £227.99
1 x OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) £209.99
1 x Asus P67 Sabertooth Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £149.98
1 x Corsair Graphite 600T Midi Tower Case - Limited Edition White £129.98
1 x Cooler Master Silent Pro Modular 700W Power Supply £94.99
1 x Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) £84.98
1 x Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) £65.99
1 x Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) £59.99
1 x Arctic Silver 5 Thermal Compound (3.5g) £6.98
Total : £1,751.48 (includes shipping : £22.20).
So mostly, I'm after suggestions if this is going to work, and/or whether I can cut some unnecessary costs out from the build. I'm hoping to keep this as quiet as possible.
Another thought going through my mind is whether I can slap in a 590 (i.e. if it will fit) and cough up the extra cash for a Dell U2711 monitor. Would it be worthwhile (obviously very subjective), and would adding the 590 increase the volume of the box to the point where all my other noise decreasing options become pointless? I wouldn't intend on overclocking the GPU, just the CPU.
Historically I'm used to nVidia, but it there is an AMD/ATI suggestion that would be quiet I'm happy to entertain it
YOUR BASKET
