Looking for recommendations ~ custom made reservoir
6 Jun 2013
Looking into getting a reservoir made to specific measurements...
Looking for recommendations of individuals/companies to approach and ask.
Thanks...
Depends entirely what is you want.
Is it a bay type or tube type res to start with?
What materials and finish surface finish do you want to achieve.
It would be to replace a reservoir in a koolance unit... the only surface that would need to be finished would be a plain clear top, with fill port. all other surfaces would be under the cowling.
I would send the original if needed and provide max available space measurements etc
