Looking for small GOU 980ti case
24 Jun 2013
Bristol
Hey guys
Looking for some help please.
I bought a cig steak Octans case from OCUK as I want a small compact gaming rig.
I've had 2 faulty cases now (just cheap plastic switches with super glue).
i have a GTX 980ti Asus which is 305mm in length (wish I went for the msi now) and I want the smallest rig possible. I have a SFX psu. 1 x 2.5 hd and 1 x 3.5 hd.
Any suggestions thanks
Budget?
N-Case M1 sounds pretty much perfect for your requirements to me and is very well built (Lian-Li after all). Only issue is that it is significantly more expensive than the Xigmatek but you get what you pay for. If you want a reasonable amount of hardware in a small case with fairly decent cooling it's the best compromise.
