Hey, just want to check if the system I've configured so far looks good or if you guys think i could build something better
It's been a LONG time since I've made a pc myself (ati 9200se days) so I'm a bit out of the loop
So far ive chosen
https://www.overclockers.co.uk/showproduct.php?prodid=GX-372-AS - Asus GeForce GTX 980Ti DC3 OC Strix 6144MB
https://www.overclockers.co.uk/showproduct.php?prodid=CP-546-IN - Intel i7-5820K 3.30GHz
https://www.overclockers.co.uk/showproduct.php?prodid=MO-022-AO - AOC G2460PG 24" 1920x1080 TN G-Sync 144Hz 1ms Gaming Widescreen LED Monitor - Gunmetal
https://www.overclockers.co.uk/showproduct.php?prodid=MB-652-AS - Asus X99-A/USB3.1 Intel X99 (Socket 2011) DDR4 ATX Motherboard
https://www.overclockers.co.uk/showproduct.php?prodid=MY-422-CS - Corsair Vengeance 32GB (4x8GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit
https://www.overclockers.co.uk/showproduct.php?prodid=HD-213-SA - Samsung SM951 256GB M.2 PCI-e 3.0
https://www.overclockers.co.uk/showproduct.php?prodid=HS-026-NC - Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans
https://www.overclockers.co.uk/showproduct.php?prodid=CA-127-NX - NZXT H230 Classic Silent Midtower Case Black
Apologies as I do not know how to use the basket function
Budget is around £1800 and I don't need a storage or DVD drives. The computer will be solely used for gaming and VR when it arrives!
Thanks for any help guys!
So far ive chosen
