Looking for some advice
9 Dec 2008
Im wanting to give my pc abit of an upgrade, I plan to buy a new pc at the end of the year.
So I only really want to spend £300ish for now which will probably just get me 1 piece
I _think_ a graphics or cpu upgrade would be best, maybe you can tell me completly different I dont know.
Im going to be playing Battlefield Bad Company 2 most of the time, and apparently that game runs super with Quad core.
My pc spec atm is:
Intel Core 2 Duo E8500 @ 3.17ghz
4GB DDR2 800mhz
ATi Radeon HD4870 1gb
What would be the biggest upgrade for me,
Graphic card upgrade from 4870 to 5850
http://www.overclockers.co.uk/showproduct.php?prodid=GX-122-PC
Or
Duo E8500 too Q9650
http://www.******.com/product/148544
Any Intel 775 CPU coolers that are recommended for frequent heavy CPU use over long periods of time etc?
So many to choose from I am clueless!
Was explained the difference between the Q9650 and Q9550 and recommended to buy a Q9550 due to BC2 performing much better on quad cores.
So Ive ordered the Q9550 :)
