Hey all
I've been a long time lurker but this is the first time I've wanted to upgrade my comp since I bought my last from here so thought I'd register!
Its been a few years since I last built this machine and I am on a limited budget (anywhere from £200-£500 depending on upgrade / new system) and would like some advice.
My current computer spec is as such....
Intel core 2 6600 running @ 2.40 Ghz
Nvidia Geforce 7900 GT/GTO
2 Gig corsair xms2 ddr2 (I think its 6400, but can check later on if needed)
Asus P5w DH Deluxe Motherboard
70gig 10000rpm boot disc
2x 320gig data discs
Seasonic 600w
Thermaltake Aguila case
Win 7 32bit
So, the machine is mainly used for gaming, I have just started playing Battlefield Bad Company 2. Whilst I know I cant get anywhere near a top of the range pc for my price range I would like something that can play this game smoothly. I'm more than happy to build my own but am not adverse to pre built models (however I know for value for money self build always used to be better?)
My current thoughts are..... (take into consideration that I will install a 64bit operating system)
Upgrade Option
Ram - Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel (TWIN2X4096-6400C5C) [TWIN2X4096-6400C5C] for 81.99
GPU - Lots of options but something along the lines of a 5770 / GT250 I guess would fit into this budget
Hard Disk - Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) - £60
Total cost of upgrade... Probably around the £250 - £280 mark depending on GPU.
New System (I could probably get away with keeping the case, Optical drive & maybe the PSU?)
This is where my lack of recent knowledge hinders me, It seems that I should be able to get an ok i3 system, or maybe an i5 but other parts might have to suffer. I have always been an intel guy purely because I know little about AMD but am happy to try either.
So if you have got this far and arent bored yet, my questions are such.
I really appreciate any help and advice that anyone can give.
Oh and apologies for the wall of text, but I thought it would be better to give more information than not enough
*Edit* Typo
Seasonic 600w
Win 7 32bit
Upgrade Option
- Would an upgrade be worthwhile? Or am I just trying to save something that isnt worth saving?
- If yes to an upgrade what would you recommend different to the limited options I've chosen?
- If no what sort of spec can I get for my limited budget?
*Edit* Typo
That said I might be able to get my hands on a Intel Core 2 Duo E8600 which should give an extra boost.
