Hi,
Thinking on trying to upgrade my machine to be able to play bf3. Tho I am not looking just to do it purely for this game it seemed as good a reason as any to have a look at trying to improve things a bit. My set up is a few years old and although I am looking to improve things a bit funds dictate that i can't buy any of the top end components so would be looking for a good bang-for-your buck approach. With all this in mind can anyone give me an idea of what to look into upgrading and perhaps give me some suggestions pls? I've posted in here before ( but not for a while as my components prob show and have since managed to lose my account details
), and have always been really pleased with the helpful feedback I have had, so hopefully i will come away with some sort of plan
Like i said the upgrade would not be specifically for bf3, but i do have that game in mind. The minimum/recommended specs for the game have just been released and read as follows (summarised):
Minimum System Requirements
PROCESSOR: 2 GHZ DUAL CORE (CORE 2 DUO 2.4 GHZ OR ALTHON X2 2.7 GHZ)
MEMORY: 2 GB
GRAPHICS CARD (AMD): DIRECTX 10.1 COMPATIBLE WITH 512 MB RAM (ATI RADEON 3000, 4000, 5000 OR 6000 SERIES, WITH ATI RADEON 3870 OR HIGHER PERFORMANCE)
GRAPHICS CARD (NVIDIA): DIRECTX 10.0 COMPATIBLE WITH 512 MB RAM (NVIDIA GEFORCE 8, 9, 200, 300, 400 OR 500 SERIES WITH NVIDIA GEFORCE 8800 GT OR HIGHER PERFORMANCE)
Recommended System Requirements
PROCESSOR: QUAD-CORE CPU
MEMORY: 4 GB
GRAPHICS CARD: DIRECTX 11 COMPATIBLE WITH 1024 MB RAM (NVIDIA GEFORCE GTX 560 OR ATI RADEON 6950)
At the moment my set up is
Processor: AMD Phenom II x4 955
Memory 4Gb Gskill 12800
GFX: Nvidia Geforce 8800GT
(Motherboard Gigabyte GA 770T usb3)
As far as I can tell my system should be able to run the game.....just...with the gfx being the main bottleneck. Do you reckon that my graphics card is the only thing i really need to look at or would it be a good idea to look into other parts as well? I dont expect to be able to play the game on full with everything on, but would like to be able to play it at a decent level.
Anyway rattled on enough for now, thanks if you got this far
So would appreciate any advice etc that anyone could give me please.
Thanks a lot
MEMORY: 2 GB
MEMORY: 4 GB
Thanks a lot
