Looking for some help with a networking solution
26 Nov 2008
Leeds
Currently studying at college without a tutor or i.t. dept so im having to try and self tutor. I have just got a bit stuck on a networking unit, I have been asked to develop a network to fit these requirements;
• One network must support over 25 iphone/ipad developers.
• One network must support at least 10 blackberry developers and 5 android developers.
• One will be for central financial and management with at least 10 devices.
• Conventional LAN but must support access for wireless devices.
• Each system connected to a core router which will provide access to the internet.
• On the core system there will be an infrastructure server and file storage server.
I am not sure if each network needs its own server or if all 3 will run directly off of the central infrastructure server, any help would be greatly apreciated.
There's no reason why you couldn't use a single router for all those devices as long as it was properly configured i.e. each department on a separate VLAN so they are segregated etc. Is that all that you are asking? Maybe they want your take on the best solution so you are free to do it however you choose?
That seems to suggest a few subnets and then a server farm on a subnet which is directly attached to the core?
Assuming the 'infrastructure' server is DHCP and DNS, you'll also need DHCP relay over the VLANs.
