Okay, so right now my PC is in a wierd situation. I have some rather dated parts, but replacing these means an overhaul on my PC. And to be honest it runs fast right now anyway.
So first off - Specs:
AMD Phenom II X4 - 3.0 Ghz (or OC'd to 3.4)
ATI HD 5870
4GB RAM DDR2
750GB HDD 7200 RPM
Mobo only has one GPU slot.
So if I wanted a new CPU, I'd also need a new mobo and RAM on top of it, and quite frankly at this time I can't afford that (I think... as I'd want an i7, fast RAM and decent mobo).
Alternatively, I just upgrade my 5870 to a GTX580 where I see a boost in gaming perfomance, which matters most to me anyway.
I'm thinking the GPU upgrade would be the wiser move, but second opinions are really appreciated
Plus, with that GPU I can take advantage of my 3D monitor.
Otherwise, my other option is to wait for the GTX600 series, but that seems like it could be some way off still :S But my 5870 doesn't exactly lag behind tons, but Battlefield 3 is making me want to upgrade!
I only run a single monitor set-up at 1920x1080.
Many thanks for any suggestions.
ATI HD 5870
4GB RAM DDR2
750GB HDD 7200 RPM
