Hey all, - follow on from my post a few months back,
Been looking into things & have come up with the below, - Just wondering on thoughts, - any critiques or suggestions.
My basket at OcUK:
Purpose is an upgrade to my old PC, - will use for Games ( a bit to start, maybe more if needed) a bit of light Graphics work / Photoshop, & my wife might use for some CAD work.
I already have a WD_BLACK SN850X for a boot / games drive.
A couple of questions:
1. It'll go in my office where I have a Monitor & a TVm so can use on either?
2. Do I need the thermal paste ( I've never needed a CPU cooler before?
3. would the PSU be adequate for the build? I did a quick check on Fastegg & it said ~600W, so I'm thinking it'll be fine, right?
4. Would I need water cooling for this? is it likely to run hot? ( I'm thinking the CPU cooler should be sufficient, right?
thx in advance....
My basket at OcUK:
- 1 x Sapphire Radeon RX 7900 XT Pulse 20GB GDDR6 PCI-Express Graphics Card (SKU: GX-3A7-SP) = £799.99
- 1 x AMD Ryzen 5 7600 Six Core 5.10GHz (Socket AM5) Processor - Retail (SKU: CP-3DW-AM) = £218.99
- 1 x Thermal Grizzly Hydronaut High Performance Thermal Paste - 1g (SKU: TH-022-TG) = £5.99
- 1 x Phanteks Eclipse G300A Mid-Tower High Airflow PC Case - Black (SKU: CA-0C0-PT) = £64.99
- 1 x BitFenix Spectre Addressable RGB Fan - 120mm (SKU: CA-238-BX) = £7.99
- 1 x Kingston FURY Renegade 32GB (2x16GB) DDR5 PC5-48000C32 6000MHz Dual Channel Kit (SKU: MY-29P-KS) = £128.99
- 1 x Gigabyte B650 Gaming X AX (Socket AM5) DDR5 ATX Motherboard (SKU: MB-5BF-GI) = £189.95
- 1 x Corsair RMe Series RM750e Fully Modular Low-Noise ATX Power Supply v2 (CP-9020262-UK) (SKU: CA-27S-CS) = £114.99
- 1 x Jonsbo CR-1000 ARGB Black CPU Cooler - 120mm (SKU: HS-00Z-JB) = £20.00
Total: £1,563.86 (includes delivery: £11.98)
Purpose of the PC 1.Purpose is an upgrade to my old PC, - will use for Games ( a bit to start, maybe more if needed) a bit of light Graphics work / Photoshop, & my wife might use for some CAD work.
thx in advance....
