Looking some feedback on how hot an intel i5 13600 should go!
11 Sep 2009
UK
I got a 13600 last week and after reading up about how much power it can use i was worried about it overheating.
I have a be quiet dark pro 4 (rated 250tdp) fitted and temps can spike into the high 90's when under full load using something like prime95.
I know prime95 is not your normal loads and is there to thrash the cpu.
Should i be worried or is it normal? Idle is sits around 32 degrees.
Anyone with similar cpu / cooler share how they get on with it?
