looking to build a basic task rig
12 Dec 2006
as a thankyou pressie for someone i thought i would build them a new pc as i know that they were thinking off up grading from thier old amd fx57
the pc is just really used for picture/video editing and dvd burning and software development. no gaming what so ever
i was thinking of the following:
http://www.overclockers.co.uk/showproduct.php?prodid=FS-268-OK&groupid=43&catid=1817&subcat=
and
http://www.overclockers.co.uk/showproduct.php?prodid=MY-221-OC&groupid=701&catid=8&subcat=1517
as i have a spare AMD 1075T & cooler here which im not using which could go in there.
would the onboard graphics be fine? as i know thier current pc still has a 6800gt in it.
The onboard graphics on that board would be fine, but I wouldn't run a 1075T on a value PSU. You don't want a fizz-bang-pop scenario. A cheap case like the Xigmatek Asgard and the 880GM-UD2H with a decent low-wattage PSU like the Antec Earthwatts 380D shouldn't run you a lot more money, and will be a lot more reliable.
ive got plenty on psu's here my attic is like a computer warehouse of odds and sods ;)
did'n really have a budget, just wanted a case, motherboard and ram to go with the 1075t, i will swap over their existing drives and dvd burner.
just trying to keep it low cost really
How about these 3 ? Not much more & gives you a quality power supply :
Case £30
http://www.overclockers.co.uk/showproduct.php?prodid=CA-160-CM&groupid=701&catid=7&subcat=29
PSU £40 :
http://www.overclockers.co.uk/showproduct.php?prodid=CA-045-OC&groupid=701&catid=123&subcat=1098
Motherboard £34 :
http://www.overclockers.co.uk/showproduct.php?prodid=MB-028-AK&groupid=701&catid=1903&subcat=
Total £104 instead of the barebones.
I've built for a friend in that case & it's surprisingly well built and good looking.
just had a quick look dont really need a case either as i have 4 spare ones:o
but dont quite think they are the right style. honestly their case dose not need changing but i didnt want to turn up with just a pre assembled mother board lol...
Corsair Builder Series CX 430W ATX Power Supply (CMPSU-430CXUK) Corsair Builder Series CX 430W ATX Power Supply (CMPSU-430CXUK) £38.99
(£32.49) £38.99
(£32.49)
ASRock N68C-S UCC GeForce 7025 (Socket AM3/AM2+) DDR2/DDR3 microATX Motherboard ASRock N68C-S UCC GeForce 7025 (Socket AM3/AM2+) DDR2/DDR3 microATX Motherboard £33.98
(£28.32) £33.98
(£28.32)
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1333C9ELV4GK) OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1333C9ELV4GK) £31.99
(£26.66) £31.99
(£26.66)
Xigmatek Asgard Midi Tower Case - Black Xigmatek Asgard Midi Tower Case - Black
You need an 800 chipset motherboard, as you want to use onboard graphics. I don't believe the motherboard that Quixote/dane suggested has onboard.
Besides that, ultra cheap motherboards are more trouble than they're worth. Get the 880GM-UD2H.
The motherboard I suggested does have onboard graphics, albiet an ageing NVidia one but fine for non gaming use. It also supports X6 CPUs. Checkout the description.
My attic really is like aladins cave.... having bit of a route through and found a msi gd65 board so maybe thinking about a seconr hand 1156 cpu??
So options are:
amd x6 1075t system but need to buy a board plus ram
or
1156 cpu system, which I will need a second hand cpu and some ram but I don't need a mother board.
Which type of system would you prefer?
also how much is a second hand say i750 gonna set me back
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey £1198.80
(£999.00) £2,397.60
(£1,998.00)
MSI GeForce GTX 580 HydroGen 1536MB GDDR5 PCI-Express Graphics Card £499.99
(£416.66) £999.98
(£833.32)
OCZ IBIS 160GB 3.5" HDSL Super-Fast Solid State Hard Drive £489.98
(£408.32) £489.98
(£408.32)
Silverstone Temjin TJ11-W Full Monster Tower Gaming Case - Black £479.99
(£399.99) £479.99
(£399.99)
Gigabyte X58 G1 Assassin Intel X58 (Socket 1366) DDR3 Motherboard - Gaming Series £449.99
(£374.99) £449.99
(£374.99)
Logitech Z906 5.1 Surround Sound Speaker System - 500W RMS (980-000469) £329.00
(£274.17) £329.00
(£274.17)
Corsair Professional Series™ Gold AX1200 High Performance 1200W Power Supply (CMPSU-1200AXUK) £229.99
(£191.66) £229.99
(£191.66)
Western Digital VelociRaptor 600GB 10000RPM SATA 6Gb/s 32MB Cache - OEM (WD6000HLHX) £214.99
(£179.16) £429.98
(£358.32)
Corsair Dominator GT 6GB (3x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel Kit (CMT6GX3M3A2000C8) £179.99
(£149.99) £359.98
(£299.98)
Asus Xonar Essence ST Sound Card £144.98
(£120.82) £144.98
(£120.82)
Plextor PX-LB950SA 12x BluRay RW / 16x DVD±RW Drive - Black (Retail) £134.99
(£112.49) £134.99
(£112.49)
Logitech G19 Gaming Keyboard (920-000978) £123.98
(£103.32) £123.98
(£103.32)
Razer Megalodon 7.1 USB Surround Sound Headset £116.50
(£97.08) £116.50
(£97.08)
Swiftech Laing D5 Vario MCP655 12V DC Pump £79.99
(£66.66) £79.99
(£66.66)
Steelseries XAI HD Gaming Mouse (62012) £62.99
(£52.49) £62.99
(£52.49)
Bigfoot Killer 2100 Gigabit Gaming Network Card £61.99
(£51.66) £61.99
(£51.66)
EK-Supreme HF - Full Nickel CPU Water Block [3830046990235] £61.26
(£51.05) £61.26
(£51.05)
EK CoolStream Radiator XT 360 (120.3) [3831109860021] £49.99
(£41.66) £49.99
(£41.66)
XSPC Acrylic Dual 5.25" Reservoir for Laing D5 (MCP655) £44.40
(£37.00) £44.40
(£37.00)
EK CoolStream Radiator XT 240 (120.2) [3831109860014] £34.99
(£29.16) £34.99
(£29.16)
Boogie Bug AimB.Pad XL Gaming Mouse Surface £17.98
(£14.98) £17.98
(£14.98)
Thermochill EC6 Non Conductive Coolant - Clear £8.16
(£6.80) £24.48
(£20.40)
Alphacool Tubing Cutter (4-14mm hose) £3.00
(£2.50) £3.00
(£2.50)
XSPC 7/16 UV Clear Blue - 1m £2.34
(£1.95) £7.02
(£5.85)
Bitspower 7/16" High Flow Barb Fitting - Matte Black [WAAD-195] £2.08
(£1.73) £41.60
(£34.60)
PrimoChill Dye Bomb - Invisible Blue £1.63
(£1.36) £3.26
(£2.72)
XSPC Tubing Clip For 1/2" and 7/16" Hose £0.24
(£0.20) £4.80
(£4.00)
Sub Total : £5,987.19
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £38.25
VAT is being charged at 20.00% VAT : £1,205.09
Total : £7,230.53
(£999.00) £2,397.60
(£1,998.00)
(£416.66) £999.98
(£833.32)
(£408.32) £489.98
(£408.32)
(£399.99) £479.99
(£399.99)
(£374.99) £449.99
(£374.99)
(£274.17) £329.00
(£274.17)
(£191.66) £229.99
(£191.66)
(£179.16) £429.98
(£358.32)
(£149.99) £359.98
(£299.98)
(£120.82) £144.98
(£120.82)
(£112.49) £134.99
(£112.49)
(£103.32) £123.98
(£103.32)
(£97.08) £116.50
(£97.08)
(£66.66) £79.99
(£66.66)
(£52.49) £62.99
(£52.49)
(£51.66) £61.99
(£51.66)
(£51.05) £61.26
(£51.05)
(£41.66) £49.99
(£41.66)
(£37.00) £44.40
(£37.00)
(£29.16) £34.99
(£29.16)
(£14.98) £17.98
(£14.98)
(£6.80) £24.48
(£20.40)
(£2.50) £3.00
(£2.50)
(£1.95) £7.02
(£5.85)
(£1.73) £41.60
(£34.60)
(£1.36) £3.26
(£2.72)
(£0.20) £4.80
(£4.00)
DPD Next Day Parcel
Total : £7,230.53
Oh if i won the lottery
