Hello!
I'm looking to build a fast system for office use. I'll be programming on visual studio as well as having a lot of memory intensive apps running (like Ms-SQL).
It needs to have a very good processor to build projects quickly
At least 6GB ram
SSD drive
My budget is ~£1000 for this system, perhiperals and software don't need to be included, just a bare bones. Willing to spend more if it offers significant performance increases.
What do people recommend? I'm thinking:
£230: Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor
http://www.overclockers.co.uk/showproduct.php?prodid=CP-391-IN&groupid=701&catid=6&subcat=1672
£168 Asrock X79 Extreme 4 Intel X79 (Socket 2011) DDR3 Motherboard [X79 EXTREME4]
http://www.overclockers.co.uk/showproduct.php?prodid=MB-057-AK&groupid=701&catid=5&subcat=2174
£140 Cooler Master Silent Pro Gold 800W Power Supply [RS-800-80GA-D3]
http://www.overclockers.co.uk/showproduct.php?prodid=CA-217-CM&groupid=701&catid=123&subcat=
£47 Corsair Vengeance 8GB (1x8GB) DDR3 PC3-12800C10 1600MHz Single Channel Module (CMZ8GX3M1A1600C10) [CMZ8GX3M1A1600C10]
http://www.overclockers.co.uk/showproduct.php?prodid=MY-314-CS&groupid=701&catid=8&subcat=
£200 OCZ Agility 3 Raid Pack 2x 120GB (240GB) 2.5" SATA-3 SSDs
http://www.overclockers.co.uk/showproduct.php?prodid=BU-112-OC&groupid=1657&catid=2101&subcat=
£100 OcUK HD 6850 1024MB GDDR5 PCI-Express Graphics Card [OcUK_6850]
http://www.overclockers.co.uk/showproduct.php?prodid=GX-174-OK&groupid=701&catid=56&subcat=
Will this all fit together? And what's a good case to get? I'm looking at AMD Bulldozers and it all seems quite a lot cheaper but I've heard sandybridge are the best.
At least 6GB ram
SSD drive
Multi is the best for working.
