- 4 Apr 2012
I have a budget of £1500, but would prefer to stay below £1000, and will be using Revit, 3ds Max, Maxwell, Rhino, and Microstation.
Currently, I'm looking at cheap peripherals, something like a Dell Ultrasharp, and a Fractal R4 for a case... and that's it
. I don't really know what components are most important for a rendering PC, so I'd be grateful for some suggestions for the budgeting of the rest of the components, and what kind of components I should be looking for.
So, things like how important the GPU is, whether I should go Nvidia or AMD, how much RAM, what speed, what kind of CPU, whether drive speed matters, and how I might use my budget to get the best balance of components.
Thanks
. I don't really know what components are most important for a rendering PC, so I'd be grateful for some suggestions for the budgeting of the rest of the components, and what kind of components I should be looking for.So, things like how important the GPU is, whether I should go Nvidia or AMD, how much RAM, what speed, what kind of CPU, whether drive speed matters, and how I might use my budget to get the best balance of components.
Thanks
