Looking to buy my first car, Need some Advice.
19 Dec 2009
Manchester
Hey All,
Right, My practical test is on the 24th of October and I've been looking at a few cars but am thinking of buying the VW Golf MK4 either the 1.4/1.6 Engine or the Tdi's. Anything I should look out for? Any Recommendations? My budget is roughly £800-1000.
Thanks!:)
I dont think £800 is likely to get a Mk4 Golf that isn't going to be a complete nightmare and a shabby mess. Especially if its a diesel. You may be better off with a Mk3.
Not really, no.
The Mk4 Golf is disproportionately expensive because it has 'cred'. This is the sort of car to avoid when you are on a really tight budget.
There are plenty of other small cars suitable for a first time driver for ~£1000 that would be better buys i would have thought.
I have a Clio 1.2 16v petrol (2002 model), love it to bits. Had for the past 8-9 years and its been great. The cars probably are not rated the best, 3 out of 5 stars on Parkers, but for me its great. It has 5 doors, yes, seats are cramped in the back. The engine is small but not too small, that 16v gives it a little kick, and I do mean little! Also, gives me around 40-45mpg.
