Looking to buy pre built system for ultra wide 1440p gaming
10 Jan 2019
My budget is between £2500 to £3000, must include a 2080 ti. I have never overclocked anything before but may look at it in the future if it gets my better fps. My monitor is the x34p 120hz ultra wide 1440p and my 980ti, i7 6700k just don't cut it anymore on ultra.
Hi welcome
The cheapest option first off would be to just buy a new gpu (2080 ti) and slot it into your current system. If you are still not happy after that then go with a new build minus the gpu.
Are you not up for building the pc yourself if need be ? Not as difficult as it might look if you haven't built one before.
Hello, I'm selling my whole system and want to upgrade to something that will last me a long time. I won't build incase I mess up and would prefer the warranty on a pre built. I have tried to configure a few systems with the 2080ti and a i9 9900k but the price difference each time I do varys a lot. All mobos are the same to me lol so not sure what is best.
Just to give you an idea. If you want the 9900K then just swap it in for the 9700K.
Not sure if you want RGB everywhere etc or what sort of case you want but you can always change that to suit.
So you can ask ocuk if they can build a system from your list of parts. Not sure what they would charge for that but you should easily be under your £3000 top limit.
My basket at Overclockers UK:
Total: £2,535.49 (includes shipping: £14.70)​
If you are open to a Ryzen cpu then go with the R7 2700/X and a solid X470 board such as the Gigabyte X470 Gaming 7. The AM4 socket is supported to 2020 so the upcoming Ryzen 3rd gen which is due in Q2 2019 would slot in with a bios update.
^^^ lees but might as well push 9900k, you've come from flagship and have the budget so push it :)
Also case with USB C port would be handy and a bit more future proof with likes of mobile phones all going that way etc :)
Since CES has hinted at ryzen 3000 performance which is great ! So either makes worth waiting, or just getting intel and skipping the 2700x since you've got the budget to go for the best !
Pre-built
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,818.82
    • Motherboard:Gigabyte Z390 Aorus Pro Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • Processor:Intel Core i9-9900K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
    • CPU Cooler:be quiet! Dark Rock Pro 4 CPU Cooler
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
    • M.2 Solid State Drive **For Operating System If Selected**:Unwanted
    • Solid State Drive 1:Samsung 1TB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E1T0B/EU)
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Mechanical Hard Drive 2:Unwanted
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Power Supply:Seasonic Focus Plus 850W 80 Plus Platinum Modular Power Supply
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • Case Lighting:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 7 working days
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Speakers:Unwanted
    • Monitor:Unwanted
    • Gaming Chair:Unwanted
    • Case:Lian-Li Alpha 550X Midi Tower RGB Tempered Glass Case - Black
    • Graphics:Gigabyte GeForce RTX 2080 Ti Gaming OC 11264MB GDDR6 PCI-Express Graphics Card
    • Graphics 2 (SLI/Crossfire):Unwanted
Total: £2,832.92 (includes shipping: £14.10)​
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,755.87
    • Motherboard:Asus ROG Maximus XI Hero (WI-FI) Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • M.2 Solid State Drive **For Operating System If Selected**:Samsung 970 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
    • Solid State Drive 1:Unwanted
    • Mechanical Hard Drive 1:Seagate 2TB BarraCuda 7200RPM 256MB Cache HDD *System Stock*
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Speakers:Unwanted
    • Monitor:Unwanted
    • Graphics:Zotac GeForce RTX 2080 Ti AMP Edition 11264MB GDDR6 PCI-Express Graphics Card
Total: £2,769.97 (includes shipping: £14.10)​
So this is what I have configured, I needed a mobo with Wi-Fi and had the rog formular before. Is the cooler ok for the i9?
@Shane12387
aorus boards are better designed , specially the price point of the Maximus, rather get the Aorus Master
if your not doing workloads, push 1tb SSD Sata 3 over NVMe drive - windows you'll notice a little bit of speed, gaming... nothing
Gigabyte after being slaughtered with poor z370 boards, now offer this guy boards to review for free - highly respected
asus does have the slicker BIOS by a good shot!
Took your advice, will Windows still be installed on the ssd, I only picked nvme as it said Windows will be installed on it.
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,773.87
    • Motherboard:Gigabyte Z390 Aorus Master Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Speakers:Unwanted
    • Monitor:Unwanted
Total: £2,787.97 (includes shipping: £14.10)​
