A few questions regarding it.
I'm currently with Virgin Media and use a standard surfboard broadband modem. I'm soon going to be purchasing my second PC. One PC will, at that point, be running Windows and one will be running Linux. I'd like for them to use the same wireless connection.
Does anyone know if there would be problems with a Windows box and a Linux box sharing a wireless connection?
What kind of router/modem would I need?
Is there any way for me to get said router/modem on the cheap (or free
A while back I had a router and plugged two PCs into it. The drop in speed seemed dramatic when both PCs were in use (although that might be partially down to my ******* flatmate of the time downloading too much). Should I expect similar things with a wireless router/modem? If so, would speed be split 50/50 automatically or would it be more adjustable so that if only one PC was actively downloading info from the internet, then it would receive 100% bandwidth speed?
Anything else in particular I'd need to know?
