I currently game on a old but much loved 27 inch 1080p 120Hz screen.
I want to keep 120Hz minimum but go up in res and size, plus I want add some ultrawide action!
Thinking of 34inch so the screen is similar height, but wider due to the aspect ratio change.
I mainly play FPS, with a little strategy stuff occasionally.
GPU is NV RTX2080.
Thinking of a LG 34GK950F which I believe will still enable G-Sync, and is arguably better than the G model.
I want to keep the price under £1k. Currently hovering over buy for the above on OcUK.
Suggestions? I have done a bit of research, but I am not really upto speed on monitors these days. Is there anything else similar / better to consider?
Cheers
GPU is NV RTX2080.
Cheers
