Currently I'm using a Coolmaster Haf 912 plus case.
Its kind of big for my desk so I'm looking to move my current spec (in signature) into a ITX case.
I'm guessing all I need is a new mini ITX motherboard and I'm all set. I have a Corsair H80i I could use too, which I haven't bothered to put in yet.
Any suggestions on which motherboard I should be getting (I don't exactly care for the high end stuff, just need a simple board for gaming etc with USB 3.0 etc the usual)
Also would anyone be able to recommend a case, the prodigy was my first thought, but its kind of big for a ITX case ^^
I realise my GPU isn't exactly the best thing to use in a ITX case (since its a blower design) but, it shouldn't make that much difference, the thing blows pretty hard (don't....) so if anything its getting rid of GPU heat from the case.
If anyone could tell me estimated tempeture increases it would be good too
currently get 30c idle, 65c max on GPU and around 55c max on CPU (with a artic freezer 7 pro, don't laugh its served me well!
