Looking to shift to AM5 - Mobo query
22 Oct 2008
Lisburn
I'm looking to upgrade to AM5 at some stage soon.
I need a mobo that's got:
Wi-Fi7 (do B650 or x670 have wifi 7?) I've got a 1Gb broadband connection and want to be able to utilise the max speeds from it if I can.
Lots of USB sockets at the back for various gadgets and devices I have.
Not fussed on PCIE 5 at this stage.
At least 3 NVME slots
Optional "would likes" but not essential
Board display for fault finding
USB 3.2 gen 2 (40Gb/s) slot
What's my options around the 200-300 mark but not really got an idea of budget.
I'm looking to get a good mobo and RAM now, with a temp CPU. Then later looking to upgrade to a "basic" 12 core AM5 CPU or a good X3D cpu
My basket at OcUK:
Total: £479.99 (includes delivery: £0.00)​
With Wi-Fi7 as a requirement you're limited to some of the higher end options, the Tomahawk is hard to beat at that price point.
Cheapest I'm aware of with a fault display is the X870 Elite.
Either would be fine for pretty much any AM5 CPU on the market as long as it was sufficiently cooled.
Not normally, no. But, have heard some of these newer boards that claim wifi7 don't have wifi7, though I don't know/understand the details.
You're aware that a lower-end AM5 CPU will be slower than your 5900X (in multithreading), right?
If it helps i have an Asus B650 TUF Wifi board. Not sure what WIFI it is but i do get the full 1100Mb ish download speed on my Virgin 1Gb service
Yep, the 7600-esq type CPU is just a stop gap for a couple of months until I get a 9900x or 9800X3D. Not planning on doing anything heavy tasking over the summer so happy to drop the cores as a stopgap, probably keep the stop gap CPU as a tester.
I've got the same Virgin service, I thought wifi 7 might have been a better option as I can't use ethernet cable option. Good to know that :) I guess the wifi7 was just for future proofing, in my head anyway. Lots of devices in the house use the connection, including the TV for streaming...at the same time. I figured the wifi 7 might have given me options to allocate broadband usage for everything better than wifi6
Yeah weve got quite a few including several XBoxes, PCs, the virgin box tv sticks the lot.
I am using a mesh WiFi Deco XE75 Pro kit (with the 2.5GB port). My PC is connected to one of these nodes using ethernet and I am hitting 1GB download speeds.
The PC node is only located 4 - 5m away from main node, but saves me having to drag an ethernet cable across the room.
i would avoid all the gigabyte boards except the stealth ice and pro ice
the rest use 12-14x 55A for the Vcore VRMs which are pretty pee poor in comparison to the competition
the board i would get is: https://www.overclockers.co.uk/asro...t-am5-ddr5-atx-motherboard-mot-asr-03308.html
14x 80A Vcore VRMs
WiFi 7
USB 40GBps
12 usb ports (10 x A, 2x C)
3x NVME slots
best of all, really cheap in comparison to other boards
cons of the PRO RS-WIFI
no fault codes, but has fault LEDs which are good enough?
Prior Asrock bioses had been blowing up ryzen 9800x3d cpus with their faulty power settings - should be fixed already with the latest bios updates though (but i guess once trust lost, hard to gain back)
alternatives to consider:
MSI X870-P - same price as the PRO RS-Wifi but lesser specs (poorer VRMs, poorer audio solution, less USB ports)
MSI X870 gaming plus - same specs as the X870-P but the nvme slots are all heatsinked (more expensive than the PRO RS-WIFI)
