Looking to spend £100 on a phone
12 Dec 2005
Would like some advice on what would be the best phone to get for around £100. At the moment i think my best bet would be the SE K750i. It would have to be a pay as you go and with O2.
Thanks in advance for any suggestions :)
Not sure how much the W810i is on PAYG from O2, but if it is over £100, it will only be so by a few £s.
Worth the extra over the K750i because:
- Slightly larger screen
- Supports flash themes
- Walkman software (K750i media player is not great)
- No joystick (these often went wrong on the K750i)
Jon
W810i (white) from o2 - £70
Go in and ask them to match the offer in currys (orange w810i for £69.99 + £10 topup) and they will do. You will have to buy the £10 topup also but you'd use it anyway. My wife did this last thursday in the milton keynes o2
