Looking to upgrade monitor
30 Mar 2011
I'm currently using a 24" Benq XL2430T monitor and want to upgrade to a 32", the two i've shortlisted are MSI Optix MAG322CQR and the Dell S3220DGF, the quandary is, which do i go for, advice and guidance would be most appreciated
TIA
There is not much between them the msi has some rgb on the back and you can use an app to change settings.
Personally i like the look of the msi dell is a bit plane.
Another one to consider .
Gigabyte 32" G32QC A 165Hz Curved FreeSync Premium Pro
Thankyou for that Micky, you were one of the sources of inspiration when i was asking about a new build previously, thankyou once again for some awesome advice
I recently bought IIyama GB34 — it got both IPS and 144Hz AND sub 400gbp price.
It's wide though, so see if that's smth you want.
