Lookups in Excel - How?
Commissario
16 Oct 2002
In the radio shack
I'm doing some stuff in Excel which I think needs a lookup table of some sort.
Basically I have a number of items and an associated number. I need to select the item using a drop-down and then have the associated number appear in a cell next to the item.
How do I do this? I'm sure it's something simple.
Ta.
Sounds like a simple vlookup formula:
vlookup(A1,B1:C20,2,false)
Where:
A1 is the value you're looking for
B1:C20 is the data table range - so in Column B would be your list that appears in the dropdown list, column C is the associated numbers
The 2 means that once the forumla finds the item then it returns the value from column 2 ie column C
False - this just makes sure that the formula pulls out an exact match.
