Loop component order.
6 Jan 2013
Yorkshire
Hello, Im just reassembling my loop and i thought i would check on the order with you guys. With my old loop order didnt matter as it was just going through a graphics card and cpu block so the flow would have been fast enough to keep the temp the same throughout the loop, but im adding second EK FC7950 into the loop now. Im just wondering if any of you guys noticed a significant drop in flow with multiple GPU covers?
I currently have the loop, Pump-Rad-Rad-GPU-CPU, if the second GPU would drop the flow rate quite a lot, then maybe i should stick the second rad between the GPUs and CPU, but i don't have temp sensors to test for any heat buildup.
I only use my d5 on speed 2 cause i like a silent PC so i would prefer to have to change the order of the components rather then have that thing buzzing away on full speed.
I figure someone has tested all this before so i thought i might as well ask before i reassemble.
Cheers.
Nvm, i found some bigger rubber washers for the pump so i can have it on full speed now with no noise so ill just stick to the current setup.
Good idea. :) Cant believe i didnt think of that lol. Guess i better start scavenging though all my old EK blocks trying to find some more barbs.
Although generally it doesn't make a difference, I would be very surprised if moving the second rad between the two gpu blocks doesn't make a big difference.
Yeah i didnt bother, i just ran the GPUs in parralel like Jim suggested and it worked a treat, my temps have gon down on the GPUs and the CPU by a fair bit, bout 5 C drop on the GPUs and 10 C on the CPU.
