Loop direction.
Man of Honour
17 Feb 2003
Chelmsford
The order of the individual components dosent really matter, just make sure you get the inlet and outlets the correct way around
This. Its always irrelevant as the water reaches an equilibrium temperature in your system anyway. People sometimes think it has to be radiator to pump to block as then the block will be getting colder water.
