HI All,
OK, I have decided on my board for the new build, Rampage 2, I am going to add the Chipsets to my loop as my current striker is a sucker for heat from the N/b - S/B.
Question is, what's the best loop setup?
I'll be using a TJ07 with Two rads in the base most likely a PA120.4 and a 120.2 (I already have a 120.3 so if I could use that instead I would! ?! ? !)
Any advice on this would be great.
Thanks as always.
Thanks as always.
