- 10 Apr 2014
- Hampshire
Since getting my rig up and running again , there has been a metallic smell coming from the rear fan , which originates from the cpu area on the motherboard.
The first time i got my rig up and running it did the same , so i sent the motherboard back because i thought it was deffective .
With this second motherboard doing the same again im thinking it is the order of my loop that is causing the problem. The way the loop goes is : res > rad > gpu > cpu > rad > res
I know there is something to do with max thermal load . what dawned on me today is that the water going to the cpu isnt actually cooled by a rad before hand so when it goes over the cpu it is mayby picking up more heat along the way and causing it to give off this mettallic smell that there is.
Atm im thinking i might have to reconfigure the loop order, anyone got any thoughts on what i should do , or any advice in general ?
other than that is there anything worrying?
