Loop Order
8 Sep 2014
Just upgrading system / adding new part and looking for advice in regards to loop order current rig :-
EK - XRES 140 D5 vario
Black ice GT Stealth 240 mm Radiator
2x ek vardar fans f4 pull
2x Aerocool DS Edition fans Push
XSPC EX420 Triple Fan Radiator
3x Phanteks PH-F140SP 140mm Fan push
EK Water Blocks EK-FC Titan X - Acetal+Nickel & backplate
current order
res / pump > 240 rad > gpu > 420 rad > res
I was thinking when i add this block to go in this order
res / pump > gpu > 420 rad > cpu > 240 rad > res
the block i will be using :-
https://www.overclockers.co.uk/showproduct.php?prodid=WC-644-EK&groupid=962&catid=1519
thoughts appreciated
It doesn't really make much difference what order you put your loop in as long as the res is directly before (and above) the pump which it will be using an xres
