Loop problem and Leak
8 Sep 2014
Hey guys so i had pretty much a big problem. The top radiator which i fit onto this system and into this loop was leaking on the right hand side. The last fan screws punctured the rad somehow. This caused it to leak but i am not sure if thats the main reason why the loop would not go completly around.
1. Could you see a problem with this loop?
2. How can i drain liquid from the rad in the front?
this is also my first time doing acrylic or a custom loop.
First picture shows loop without any liquid in it.
Here is the picture with the loop filled but the tube was cut to drain some liquid out so i could take the rad out via the front bays.
The loop is running this way and when u turn on the pump the liquid in the res was pushing up. Now am not sure if this was due to the puncture in the rad but is this supposed to be ok? or is something wrong with the loop. The top this is just fill port on the res and obvously pipe was cut after the leak.
Here is how the liquid flows and you can work out the rest.
Would really like some help thnx
That would be nearly impossible to achieve. The blocks are often multicard / multisocket compatible and cpus sockets vary in location slightly board to board and socket to socket
I wanted to laugh after I checked the EK plans for that pump ( just now ) how in the hell did you not see the flow was into the res ?
I filled my loop from the res to see if the pump was Flowing to or from the the res before i filled up, man you must have been super excited to miss that.
Indeed shame about that tube you cut that looked like a mission !
Also did you not have lots of trapped air in the loop after you filled it because of all the air space in the res would have been pressurized once you closed the loop ?
