Loop Tap?
Yes but it must be bspp to be compatible with g1/4". An npt thread will need to be tapped out.
Usually the pk stuff will state specifically if it is bspp, phone or email them with the item number, should be able to tell you exactly what thread it is.
That looks about the same thing just cheaper :)
Not sure about mounting plates, could just get a small piece of wood and drop a couple of u-bolts over it.
